Seating in a concert hall
#1
Posted 12 August 2012 - 02:16 AM
I assume the basic differences sound-wise would be that closer to the player the sound would be not quite as smooth as further back? Is there any other phenomenon or things to consider?
I sat in the third row a few weeks ago watching James Ehnes perform Bach's BWV 1004 and it was great. I would like to sit close again at the next show just for the visual excitement but don't want to sacrifice sound much.
Here is a link that has a seating plan for the next show I have planned to go see...Chloe Hanslip doing Paganini's 1st concerto on a del Gesu! I'd be curious to hear your comments on the seating plan on the link. Why is the 'A' seating section more expensive (better) than others? I'm tending towards sitting near the front of the 'C' section unless there are good reasons not to.
http://www.edmontons...ical-fireworks/
Thanks you, curious to hear your responses.
#2
Posted 12 August 2012 - 10:12 AM
If you could become friendly enough with someone to be able to go to the rehearsals, that would be great. You can hear the violin from different spots.
#3
Posted 12 August 2012 - 01:46 PM
Personally I would prefer a mid orchestra seat.
There are some "seat dip effect" which might remove a little of the sound level in the 250Hz band where the main air resonance are in a violin. (Which range the seat dip effect works depends on the seat distance and details in the geometry). I suppose that you will have less of that in any of the front baclony rows.
Rearmost seats can be quite clear due to the backwall and sometimes ceiling reflection. They are not necessarily bad, can sometimes be quite good.
Under balcony seats will often be drier sounding and less loud, more so the deeper the balcony and the lower the ceiling
#4
Posted 13 August 2012 - 01:28 AM
#5
Posted 13 August 2012 - 06:19 AM
Where to sit will also depend on your personal preferences in room acoustics. The first row at any of the balconies close to the centre would give a balanced and somewhat more reverberant listening field. Closer to the stage, e.g. in the centre of the orchestra, would probaly give some more clarity.
One of the most frequently used concert venues around here is a very "wet" (=reverberant, opposite of dry) hall. So wet that a pianist hardly needs to use the pedal! When I've listened to string quartet concerts sitting in the middle of the orchestra section the sound has been too blurred by the reverberation. Front row of the balcony has been good and, in accord with Anders's comment, on the main floor under the balcony overhang is also good. I think good seating will vary from hall to hall and person to person. If you tend to use the same hall you could experiment to find the place that works best for you or ask other people what they prefer.
#6
Posted 13 August 2012 - 03:27 PM
#7
Posted 13 August 2012 - 05:22 PM
A great advice! Usually the halls will sound more wet or more reverberant under rehearsal conditions. But attending rehearsals is a great opportunity to explore any preferences in room acoustics as well.If you could become friendly enough with someone to be able to go to the rehearsals, that would be great. You can hear the violin from different spots.
A grand piano with the damping off will be more reverberant than any normal concert hall. The RT of the lower notes are 20 seconds +. Interestingly the percussive part of the piano note makes it sound ok even in excessivly reverberant spaces. At least that is wheat litening to aurlaisations of piano music in such rooms have indicated. Electric guitar is another very reverberant musical instrument. The guitar sustain will override any reverberance in a normal venue.
Our Hardangerfiddle has a reverberation time exceeding normal concert hall reverb too, at least in the lower notes. The ring comes from the undamped sympathetic strings, but is somewhat weak. A guess we are all familiar with the ring in stringed musical instruments, cello, harps etc. But even the organ has some reverb in its pipes and thus notes, although the room very much is part of that instrument.
#8
Posted 13 August 2012 - 09:43 PM
Many halls have seats on the side balconies and you have to turn your head and strain your neck for the whole concert.
#9
Posted 14 August 2012 - 01:43 PM
#10
Posted 14 August 2012 - 03:28 PM
