plane cap iron video
#1
Posted 23 July 2012 - 03:43 PM
#2
Posted 23 July 2012 - 04:53 PM
Oded
www.kishonyviolins.com
#3
Posted 23 July 2012 - 06:01 PM
#4
Posted 23 July 2012 - 06:13 PM
#5
Posted 23 July 2012 - 07:07 PM
...Don't view it if you are not really interested in how your plane works...
I am interested in how planes work. I found this video fascinating.
#6
Posted 23 July 2012 - 08:26 PM
I found this video very interesting. For violin makers, probably helpful in using a plane for the center joint. Don't view it if you are not really interested in how your plane works. You will be bored to tears.
Wow, I didn't read your entire post and just clicked on the link, I almost started crying...
#7
Posted 23 July 2012 - 08:33 PM
Ha, ha. Tears of boredom, no less. I told you so.Wow, I didn't read your entire post and just clicked on the link, I almost started crying...
...But interesting video none the less!
#8
Posted 23 July 2012 - 09:22 PM
#9
Posted 23 July 2012 - 11:18 PM
#10
Posted 24 July 2012 - 12:47 AM
neil
#11
Posted 24 July 2012 - 07:18 AM
...what is 0.1 mm in an english fractional unit?
about 1/255
#12
Posted 24 July 2012 - 12:26 PM
25 mm per inch
1 mm is 0.040 in.
0.1 mm is 0.004 in
0.05 mm is .002 in
10 cm is 4 Inches
30 cm is a foot
1 Meter is a long yard.
500 gm is a big pound
1000 kg is a long ton
100 Km/Hr is 60 MPH
The exact conversions are for machinists and accountants!
#13
Posted 24 July 2012 - 09:55 PM
Yeah, maybe it was the music, but I felt like I was in a trance. Help me here, I use a plane, but don't know that I have ever used a "cap iron". Can anyone explain? I see the difference...actually extremely interesting. What happens if you use a hollow grind on the upside of your plane?mesmerizing
Oded
Jeff White "When only used will do"
#14
Posted 25 July 2012 - 12:43 AM
On a “Stanley style” plane you have the chip breaker (or cap iron) usually screwed to the blade and the lever cap using sprung tension to hold the blade and chip breaker firmly in place.
On a block plane there will be no chip breaker/cap iron and the lever cap will with a screw mechanism usually hold the blade down against the bed of the plane.
Generally bench planes (such as smothers, panel and jointers) will have the ground bevel on the plane blade facing downwards, where as smaller planes such as block planes, chariot planes, shoulder planes etc. will have the bevel facing upwards.
Traditionally a bevel down plane will have a chip breaker/cap iron and a bevel up plane won’t.
There are plenty of exceptions to this very general rule and today there are plane makers producing bevel down planes without chip breakers and traditional sized bench planes that are bevel up.
Neil
#15
Posted 25 July 2012 - 07:27 AM
Berl
McConnelsville, Ohio
#16
Posted 25 July 2012 - 07:37 AM
I'm with Neal on this. I found it very interesting. Not hard for me to watch. I'm a tool geek though. There are few things in wood working that feel better than using a sharp, tuned hand plane.
Berl
Berl,
Yes. Same for me too. OTH, I know a very smart fellow who is an amateur woodworker. He said he uses handplanes. When I asked him about his sharpening method, what kind of honing stones he uses, he said, "No, I just grind." So he has never used a sharp plane. Wow. I expect him to mail me his plane blades so I can really sharpen them.
#17
Posted 25 July 2012 - 10:26 AM
I use the break disk hone that I made from your postings here,Is that your idea? ....thanks! works great .Right now I just back the thing up to a drill press with a rubber sanding drum in the chuck for power...works a charm...I used the seat adjustment from an old bicicle for a tool rest.Berl,
Watching the vidieo I'm reminded of water, air ...and of cut angles for hardwoods,that a steeper angle can help reduce tearout with non cap iron blades,The increased angle acts more as a plow with increased shear force compaired to tensile -splittling force on the wood. anyone know the max angle? I THINK I heard 50 degrees. An increased angle seems like a good workaround for a bevel up blade.
#18
Posted 25 July 2012 - 11:02 AM
#19
Posted 25 July 2012 - 11:16 AM
$5 for a #4? "sounds like a lot of monney."Check out his other video. It gets pretty funny toward the end!
Buying a Smoothing Plane
#20
Posted 25 July 2012 - 11:52 AM
Mike
