How to sharpen a blade with a curved edge
#1
Posted 06 July 2012 - 09:19 PM
#2
Posted 07 July 2012 - 03:52 AM
Bob
#3
Posted 07 July 2012 - 05:32 AM
Thanks. People heat treat with a torch. But after doing lots of reading about steel, particularly O1, I built a kiln with very good temperature control, and an oil bath with good temp. control. It seems I have found a good recipe. I am getting very positive feedback from violin makers.Hi John, Clever and interesting! Glad you perservered with the O1 ,its a great steel if treated properly.Your heat treatment sounds interesting
Bob
I think you CAN harden with a torch, but I think the results are far from optimum.
I would like to hear from others who sharpen curved edges. How do you do it?
BTW, my method should work on a Tormek, although I have not tried it, since I don't have a the big T machine.
#4
Posted 07 July 2012 - 06:28 AM
From [a Diary of] a Nobody - I use a curved action of the hand/arm to move the blade on the flat surface.
Works fine for me.
A Fool knows no limits.
A Fool and his money are soon parted.
#5
Posted 07 July 2012 - 08:20 AM
After using these for a few weeks now I can see why Sam Z and Collin liked these knives. Good stuff.
#6
Posted 07 July 2012 - 11:15 AM
congrats John on your breakthrough discovery !
Oded
www.kishonyviolins.com
#7
Posted 07 July 2012 - 12:48 PM
Andrew,I wonder what they intend to do with 21 knives, a circus act ;-) ????
Oded
Thanks for the compliment.
Oded, I imagine they plan on using some of them as gifts. And also, from talking with Collin, I got the impression they plan to use these knives a lot, and for a long time, until they get too short. He wanted the whole blade hardened. Also, there were 4 widths of knives, 9 mm, 12 mm, 16 mm and 19 mm. So that's about 6 of each type.
BTW, they showed them at Oberlin and took orders, which I totally appreciate.
#8
Posted 08 July 2012 - 07:11 AM
foolin with fiddles
#9
Posted 08 July 2012 - 08:23 AM
Thanks,Congrats, glad you found a good process and are being successful at it after all the experimentaion
Yes, it is gratifying. Now my worry is quality control. It only takes one bad blade to initiate a whole lot of negative comments.
Janito,
We need more nobody's like you.
#10
Posted 08 July 2012 - 10:03 AM
#11
Posted 08 July 2012 - 10:49 AM
Mike,It is easy to sharpen a curved blade. All it takes is a sharpening stone / hone and a little hand eye coordination. Why make things so complicated?
I guess I am lacking in coordination and training.
#12
Posted 08 July 2012 - 12:44 PM
Most pocket knife have some curve in the blade so practice on a cheap one. There are lots of sharpening videos so I just picked this one. As you push the blade along the stone you swing it around to follow the curve and at the same time lifting the back of the knife as you get into the curve and into the point, that keeps the edge angle uniform. It just takes a little practice. I've had a knife in my pocket since about 6 years old so it tends to come natural I suppose.
Practice with a spay blade, now that's a curve!
#13
Posted 08 July 2012 - 01:07 PM
Hand sharpening is fine but its not totally accurate or perfectly repeatable,but useful to learn for your own tools.
If you want more expensive you could try this Wicked edge
#14
Posted 08 July 2012 - 01:20 PM
Mike,
Thanks for trying to help me out. I watched the video. I am really much too compulsive about accuracy in holding the blade angle. For me, I need a method which is more rigid in holding the correct angle.
#15
Posted 08 July 2012 - 01:28 PM
for instance i have one antique arkansas stone i use for my finest work, i cant imagine in a million years finding a grinding wheel of that quality
Specializing in the research and restoration
of baroque, transitional, and modern violins.
http://www.violinist..._johann_taylor/
(violin shop ad, with links to instruments for sale, pictures of
violins I restored, and recordings and pics of my clavichords)
#16
Posted 08 July 2012 - 01:40 PM
Lyndon,the main advantage to hand grinding, is you can have a much larger selection of quality grind stones to choose from than you might on a grinding wheel, plus you never have to change grinding wheels
The other thing to note is that I can imagine using the back bevel shoulder as a guide. I CAN envision that method working for me. Also, even though my Makita stone is supposed to be 6000 grit, it moves very fast and I think slowing it down would give me a better final strop. The wheel turns maybe at 180 rpm. This is a Delta grinder, an old one. My use of the vise grip is probably transferable to the Tormek. I don't know.
I concede that trained violin makers can sharpen by hand. I am not trained. Maybe in my next life.
#17
Posted 08 July 2012 - 02:29 PM
#18
Posted 08 July 2012 - 07:47 PM
Brian,Here's a photo of one of Han's Nebel's knives. . . . .again!!
. He hollow grinds on an 80grit 6" fast bench grinder then sharpens on japanese water stone's. With a bit of practice you can keep the edge in contact with the flat stone using the hollow. I've tried using the Tormek but the diameter is too big leaving too small a hollow making it difficult to keep the edge in constant contact with the flat stones. However, I find the Tormek very useful for quickly grinding of the shape of the blade.
If the blade comes out of the handle, I recommend you try the vise grip idea on the Tormek. If you want a larger radius of curvature on the edge, just make some kind of extension for the 6 inch vise grip. I grind blades that are long and thin like this on my belt grinder wheel. Works great.
#19
Posted 08 July 2012 - 09:23 PM
Hans just used my main knife (curved blade)in a sharpening demo at a workshop a few weeks ago. He still uses the way mentioned above. However, he flattened out my cure, but it is, wicked sharp. Interesting, watching him do this,likes to use his hand a pivot. I guess a human version of violins88's jigHere's a photo of one of Han's Nebel's knives. . . . .again!!
Jeff White "When only used will do"
#20
Posted 09 July 2012 - 04:54 AM
Jeff,Hans just used my main knife (curved blade)in a sharpening demo at a workshop a few weeks ago. He still uses the way mentioned above. However, he flattened out my cure, but it is, wicked sharp. Interesting, watching him do this,likes to use his hand a pivot. I guess a human version of violins88's jig
. jeff
If you want to use stationary stones, you could clamp on the vise grip and then install a post in your work bench to receive the pivot end of the vise grips. I am confident the geometry works out. I guess I (or someone) need to engineer an aesthetically pleasing vise grip. Actually I hate the look and feel of the vise grip for this process, and it needs to be much lighter, even though it does the job. The mass of the grip reduces the ability to feel what's going on with the edge.
