Wood Selection: Discoloration in Ribs
  • Please log in to reply
13 replies to this topic
#1 Joseph Swenson
Joseph Swenson
  • Members
  • 304 posts
  • LocationLivermore, CA
Posted 22 June 2012 - 03:13 PM
Hi Again :)
OK for my second grousing... I revceived in my viola wood order from Metropolitan Music some Pahler Tone wood, Nice quality matching flamed 2 piece maple back, neck, and sides.
I started examining the ribs and about 1/3 of each rib has this unattractive discoloration in the rib through the grain.
Posted Image
Posted Image
I tried scraping down one rib and it was still just as much a problem and perhaps even more visible.
I know this will show up in the final appearance of the instrument. Am I crazy to complain? I can use the ribs just not the discolored sections so I'm thinking I will ask for a couple additional rib pieces hoping they'll match, or should I ask for an entire re set and hope for the best as I did with the select viola top? - Which as you might have seen from my last post, the problems with the replacement was worse than the original problem.
Thanks again for your observations!
Regards,
Joe
So much to learn... so little time...
#2 John Cockburn
John Cockburn
  • Members
  • 1325 posts
  • LocationSheffield, UK
Posted 22 June 2012 - 03:27 PM
I think that will be absolutely fine. You probably won't even notice the discolouration once it's varnished.
#3 arglebargle
arglebargle
  • Members
  • 385 posts
Posted 22 June 2012 - 03:29 PM
It looks like mold/fungus to me.
I would just go ahead and use it.
With some planning you should be able to place the effected spots in less noticable areas, like the upper curve in the c-bouts or the lower bouts under the chinrest.
Shouldn't be too noticable after it's varnished.
Good luck.
#4 Wm. Johnston
Wm. Johnston
  • Members
  • 1952 posts
  • LocationFort Collins
Posted 22 June 2012 - 03:36 PM
I would use this wood. If you plan carefully then you can probably avoid using most of the discolored wood or place it in a tough to see spot like the corners on the c-bouts.
Website
Available Instruments
Not a member of the magic potion school of violinmaking.
#5 lyndon
lyndon
    still trying to post #4090
  • Members
  • 4089 posts
  • LocationWest of Cremona, East of Beijing
Posted 22 June 2012 - 03:53 PM
once again, buy your wood from a specialty tone wood supplier
Taylor's Fine Violins, Redlands, S. California
Specializing in the research and restoration
of baroque, transitional, and modern violins.
http://www.violinist..._johann_taylor/
(violin shop ad, with links to instruments for sale, pictures of
violins I restored, and recordings and pics of my clavichords)
#6 arglebargle
arglebargle
  • Members
  • 385 posts
Posted 22 June 2012 - 03:54 PM
Jinx! Buy me a Coke! ;)
#7 Oded Kishony
Oded Kishony
    grand poobah
  • Members
  • 5773 posts
  • LocationCentral Virginia, USA
Posted 22 June 2012 - 04:08 PM
You might be able to get rid of the staining with a dilute solution of oxalic acid (hardware store), try it on a corner of the ribs.
How much shows in the final product depends on how clear your varnish is, whether you intend to antique the instrument, how much color you will apply to the instrument, if you intend to sell the instrument and how naturally fussy you are.
Oded
visit my home page at:
www.kishonyviolins.com
#8 Johnmasters
Johnmasters
  • Members
  • 4220 posts
  • LocationColumbus
Posted 22 June 2012 - 04:39 PM
Hi Again :)
They gave you FOUR lengths, you only need three. You should be fine.
#9 Joseph Swenson
Joseph Swenson
  • Members
  • 304 posts
Posted 22 June 2012 - 04:52 PM
Yes I was initially measuring it out to see what the deal was, and one length is not enough wood for the lower bout. So I in fact need all 4 lengths. These ribs are almost the same length as the violin ribs I used.
I spoke with Metropolitan Music and they are going to try and match the ribs and send me a couple more pieces.
They are VERY accomodating so I can't complain too much. But I can't imaging if the flamining is going to show through the varnish in the end how this discoloration could possibly be hidden. And my point really is if I'm payting for a certain grade wood why settle. Its like like getting poor quality food in a good restaurant.
Thanks for the comment Lyndon. Do you have some recommendations? (I'm on the West Coast US)
Cheers,
Joe
#10 robertdo
robertdo
  • Members
  • 2380 posts
  • LocationDurham, UK
Posted 22 June 2012 - 05:08 PM
Cheers,
Joe
But it looks like Andreas Pahler is a tonewood specialist, according to his biopic. On the Metropolitan music his name is beside Simeon Chambers's one.
#11 Joseph Swenson
Joseph Swenson
  • Members
  • 304 posts
Posted 22 June 2012 - 05:51 PM
Pahler is German tonewood accoring to Met Music. SO it's either the buyer for Metropolitan Music or the "wood guy" as the sales person on the phone put it today, who needs to be more selective in what they ship out. I've had to return a few items recently. Maybe they just need confiscate this "wood" guy's flask. ;)
Joe
#12 MANFIO
MANFIO
    MANFIO
  • Members
  • 8432 posts
  • LocationSao Paulo
Posted 22 June 2012 - 06:41 PM
This is not a problem, you will not notice it under the varnish.
#13 Don Noon
Don Noon
    Using tools without supervision
  • Members
  • 3698 posts
  • LocationCarlsbad, CA
Posted 22 June 2012 - 07:39 PM
Just one more vote:
Plan as best as possible to trim the discoloration and/or have it in the corners, and it will disappear under the varnish anyway.
Making fiddles ain't rocket science... it's much more complicated.
#14 Michael_Molnar
Michael_Molnar
    Stargazer
  • Members
  • 3831 posts
  • LocationWarren, NJ
Posted 22 June 2012 - 08:28 PM
Joe
Andreas Pahler is highly reputable. You have more than enough good ribs to use.
