The cabinet is made out of MDF sheets. There are only six screws holding this together.
The panel corners are built up by gluing MDF strips to form mated slat corners. MDF is great for containing noise, but I added white ceiling panels to the interior which helps even more.
Air is pulled across the work from the five left vent holes.
Wood chips and dust are drawn into the large vacuum port seen behind the gantry in the photo.
The front door is lifted into place and mates with the corner slats. The window is very useful to check on the CNC.
The aluminum bar running across the from door stops the door panel buckling inwards when the vacuum is on.
The rubber strip above the door protects my bare bald head from striking the cabinet roof edge when the door is off.
