With all the conflicting opinions that fly around it would be fantastic to be able to hear a set of recordings like this...
Yes it would be fantastic.
Posted 20 December 2011 - 09:51 AM
Posted 20 December 2011 - 09:56 AM
Posted 20 December 2011 - 10:11 AM
Carl, you could do better than to flail about wildly, with little idea of what you're talking about. The writing style and the content remind me of someone else here.
Of course we took steps to try to differentiate between actual sound, and other influences, such as Rene's accent and personality. I considered that to be a basic part of my job. It doesn't serve attendees if I bring back teachers who can't get real results.
One of the ways we did this was to record before and after an adjustment, let some time elapse, and then play back loops of these recordings in various orders, with the order unknown to the listeners. Nothing but the music. No French accent. I wouldn't have put my a$$ on the line, saying Rene got results, without having done things like this to try to separate real results from psychological factors. We actually took it far enough that one of his former employees took me aside for a little talk, quite offended by the level to which we required Rene to prove himself.
I have no idea what you mean by suggesting that we discovered
"that in a large hall a violin's spectrum and phase relations are completely different from a small room".
There was no such "discovery". It was something we already knew, and that's one reason why adjustment progressions were done in both a room and a hall, to validate the process in more than one environment.
It sounds like you have the workshop I directed confused with some other workshop or group.
It's kind of sad that when some people haven't been involved with the people who can get results, or don't get results themselves, they conclude that the results must not be real. It's much more productive to learn.
Actually, we still have the sound files from these adjustments, and meticulous notes to go with them, so maybe it would be fun to play them for a group at one of the conventions, and let you eat some crow.If you can't hear the difference, or hear an improvement, I'll guarantee that most other people in the room will be able to.
I'd put some up here or on my server so others can judge for themselves, but they are huge uncompressed files.
Posted 20 December 2011 - 11:48 AM
If you will commit to being to being at the next VSA convention, and there is enough other interest, I'll make an effort to get it onto the agenda. I think it would be much more valuable, and a better use of my time (and Pasewicz's time, he's the one with the notes) to present this to a group, listening to uncompressed files, in the same room, and through the same sound system.David, give us some of the sound files and the meticulous notes. Are we talking "ajustements" by the tenth of mm or by the cm ?
I take it that you've experimented enough with non-standard positions, on enough different instruments, to know this for sure?The s/p is a simple mechanical device with a couple of simple functions. Violins are built on close enough lines for the post to have an almost standard position.
Before you criticize a man you should walk a mile in his shoes.
That way when you criticize him you will be a mile away and you will have his
shoes.
Burgess Instruments
Oberlin Restoration Workshops
The sooner you fall behind, the more time you'll have to catch up.
Posted 20 December 2011 - 11:54 AM
Jeffrey
J. S. Holmes Fine Violins, LLC
Oberlin Summer Restoration Workshops
Oberlin Summer Instrument Restoration Workshop on Facebook
Posted 20 December 2011 - 12:02 PM
Carl.... You a 'cellist?
Posted 20 December 2011 - 12:12 PM
Yes, Rene could really produce results.
Of the various players we brought in from the Detroit Symphony and the Cleveland Orchestra, there was only one case where Rene's improvements were judged shaky or nonexistent. And I believe I know adjusters who are better than Rene.
Posted 20 December 2011 - 12:18 PM
Posted 20 December 2011 - 12:41 PM
LeMaster, my phone is 734 668-7803.David, when you can pull yourself away from your workbench for 5 minutes please give us 3 names and contact info. I'll put you on my Zingerman's Christmas list.
I know you're obsessed with quality, but nonetheless your Webpage won't let me 'contact' you privately.
shoes.
Burgess Instruments
Posted 20 December 2011 - 01:17 PM
The email isn't on my web site because I didn't have time to deal with all the spams, "I found a Strad" emails, repair inquiries, rental inquiries, people who wanted a quote on a case or an E-sting... all the stuff I don't do. For some reason people are much more selective about using the phone.
Posted 20 December 2011 - 01:24 PM
Sorry, I'm not making a living unless I'm making violins.
I take it that you've experimented enough with non-standard positions, on enough different instruments, to know this for sure?![]()
Back graduation patterns and stiffnesses are all over the place. Do you really believe that "an almost standard" post position on the back works best for all, including one where a back is 2.7mm thick at the standard post position, and another where it is 4.7mm thick?
Posted 20 December 2011 - 02:29 PM
Really? Are you talking about theoretical violins, or theoretically ideal violins, or real violins?In a violin variations of stiffness and weight are compensated nicely by the curvature of the plates and the post needs to maintain a certain ratio which basically decides it's position too very close variation . At least in well made violins. As the local stiffness varies with the CUBE of thickness we should see the s/p all over a much larger area. ANd we don't.
shoes.
Burgess Instruments
Posted 20 December 2011 - 02:50 PM
Hey hey, that hurts!
Jeffrey
Posted 20 December 2011 - 03:11 PM
Jeffrey
Posted 20 December 2011 - 03:16 PM
In the case of real violins, it's often possible to find a "non-standard" post position on the back which works quite well, better than the "standard" it came in with. I think you'd see it more often, except that people tend to get stuck on some didactic set of rules, and never even investigate other possibilities.
I've mentioned this a few times before, but Doug Martin has played a big role in showing how silly some of our sacred rules are, with his wildly unconventional fiddles, which can sound pretty darned good side-by-side with conventional fiddles of merit.
Posted 20 December 2011 - 04:57 PM
Really... It was just an honest question!
Posted 20 December 2011 - 05:25 PM
Posted 20 December 2011 - 05:40 PM
I think I've covered that ( type of violin ).
You said that Renee Morel demoed his system of adjusting the s/p position. I believe ( wrongly it seems ) that such tinkering around standard position has small influence over some 4 octaves, being FAR outwighed by the need to have a PERFECT fit. More so, I believe a tipical violin ( like you make ) is inherently designed to receive the s/p in the standard position ( that's were you put it ). I might be wrong, of course.
I also believe that making micro adjustments of the s/p is a great marketing ploy. Akin to those two blokes who shaved a bridge until there copy sounded more like the original.
Now, again. what was Morel's system ? He listen to WHAT ? Heard WHAT ? And did WHAT ? You were there, organised the thing, I have to suppose that if it was of any importance you will remember. Or he forgot to explain AGAIN ?
Can you tell us ?
Let me make it easier : how did Morel know when the s/p is too much to the W ?
Posted 20 December 2011 - 05:47 PM
shoes.
Burgess Instruments
Posted 20 December 2011 - 06:10 PM
0 members, 0 guests, 0 anonymous users
